Suggest me an extremely low power opamp
rogger123
Full Member level 1
low power opamp
can any one suggest a circuit for low power opamp
any architecture which can give extremley low power.
gain bandwidth is just 500hz
slew rate .2v/uS
supply +/- 2.5v or less.
input vtg swing of +/-1v
Re: low power opamp
if u r looking for a low voltage low power opamp use lm358!
BEST!
Re: low power opamp
I suppose two stage opamp architecture is a very good cjoice for your specifications,
a differential stage as the first one, followed by a common-source second stage.......
low power opamp
try MC33272A, MC33274A,
NCV33274A
Re: low power opamp
I think the two stage can meet you spec. The topolog is :
the folded-cascode input stage & class AB output stage;
the general differential input stage & common source sigle amplifier output stage;
the P&N parallel differential input stage & class AB output stage;
or the single folded-cascode amplifier;
or the regulate folded-cascode amplifier;
low power opamp
u also can try ad847 low power opamp.it is just as sameas lm741 but low power and low noise
low power opamp
what is your OP-AMP's gain(f=0)?
