Suggest me a final year project which includes FPGA(Verilog),PCB and GUI design
tom_hanks
Full Member level 5
Full Member level 5
Hi Friends,
I am looking for a Project....
Which include FPGA(Verilog),PCB and GUI design..
Can somebody suggest me a project...
or is there any chip/bridge, which is absoloute from the market....
so i can use that as my project..
looking forward for your help
Re: final year project
concerning FPGA i have three projects you can choose one of them
but i didn't make any one of them because i took another project
1- implememting of function generator on one chip
2- make coding chip that can code any transmitting signal
3- up-down converter
dear ceaser,
thnks for mail..
could you please put some focus on
"make coding chip that can code any transmitting signal "
could you pls describe with example..
it sounds interesting..:D
Deer tom
i ment by chip can encode any transmited signal that the chip can make line and
channel coding by all types of digital coding
for ex:
when chip take order to code the entering signal to CMI or Manchester code or
unipolar or polar non return to zero, it makes processing to take out the
corrseponding code
ex for CMI:
it takes 4-bits by 4-bits and code them
for manchester it reads if it is one or zero
    tom_hanks
Dear Ceaser,
it is bit clear...
could u pls tell me the application of such coding chip...
tc,
tom
Hi Tom
this chip is used in digital communications.
it takes the digital signal then make processing on the signal to make it ready to be modulated
(modulation mean that we raise the frequency of signal to be suitable for transmission)
then the transmiter transmite it .
we make this line and channel coding in order to speading the bit rate of tranmitter and for small secure and for eleminating DC component of the signal if the signal has it (ex: three ones and two zeros have DC component)
and ather useful applications in transmition i don't remember it right now
thx Tom
Dear Ceaser,
Thank you...
still i am thinking and working on other things as well....
once i will finalise..
i will get back to you again...
bye for now..
tom
hi if you r interested in vlsi project then there r lots of project which i had made including digital thermometer ..if you r from india then i can help you or go to link h**p://www.geocities.com/deb_mallik/cpld for more details or contact me at deb_mallik@yahoo.com
hi deb,
yes, i am looking for VLSI based project...
it should include HDL,Board design and PCB....
tia,
tom
hi deb,
thanks ..
yes i have checked your website...
im looking for a project which include HDL,board design and PCB..........
if u can suggest something..it would be appreciable..
cheers,
tom
i can suggest you a project for digital thermometer using cpld ..you have to design pcb for the same ...code in vhdl ..and programmer to program in cpld.
also which country r u from ?
bye
HI Deb,
Thank you input...
let me study this project...
cheers,
Tom
UK
