Substitute for IRF9z34
annna
Member level 2
Member level 2
pak
My area's electronic component dealer is out of IRF9z34.....
So, I need a replacement for it can anyone tell me its equivalent.......
You'll need to give more information on which footprint you need and how this device is being used. Generally, to find a substitute:
1) Ensure the footprint/pin-out is the same
2) Make sure the Vgs, Rds, Vdss, and Power are the same or better.
3) Make sure the new device is also a p-channel MOSFET.
Most manufacturers allow you to search by parameters. Digi-Key also has a fairly good parameter search.
Reactions: annna
    annna
