Stupid `include directive problem....
jelydonut
Full Member level 4
Full Member level 4
I've never had to do this before and now that I have to of course it turns in to a issue...
Im trying to make a .h file consisting of parameters which I can just `include at compile time. For some reason the parameters only seem to work if i just have them in the module itself..
any ideas?
jelydonut
@jelydonut
It sounds like a multiple including. This usually causes errors so you might want to use an #ifndef statement.
I'm not sure if you have c++ book so I'll give example.
********Class File*******
#ifndef MyType_h
#define MyType_h
#endif
*******End Class File******
What this does is, if this class is included from a main function call (#include), the ifndef determines if it defined earlier.
If it was, don't re define. But if it wasen't, then continue to the end (#endif).
Hope this helps
WA
Hi, WA, `include seems more like verilog, not C++
yeewang quotes:
It is my understanding that both languages are similar.
I'm not too familiar with the syntax of verilog though.
I believe that verilog and vhdl were deliberately made similar to c++.
I think this was done so we didn't have to learn a whole new language to programming whatever device we're using (ease of learning?).
But there is some differences though.
For example, if you look at a vhdl listing for an or-gate (or something similar), you will see that it looks like an sub-function in c++.
Again hope this helps.
WA
I was refering to Verilog.. I forgot to mention that..
It turns out though I was putting it below the `timescale directive.. and for a parameter to work it has to be located inside the module.. so once I moved it, it started working..
jelydonut
