rdpdo2002
Junior Member level 2
Hello,
I would like to calculate the impedance between the two plane of a PCB when electromagnetic fieds expanse in the dielectric to illustrate how the cavity resonate.
My aim is to put some GND via to illustrate the resonnance changing.
I tried to make a wave port on top and on bottom to get S parameter but got error because plane on bottom is perfect conductor.
So I am trying to use field calculator to estime impedance. I first try to get capacitance using Q=CV ; I can have Q on top and Q on bottom but to get Voltage across top and bottom I need to integrate E along Z between the two planes... but for each line on the volume... I don"t know how to do ??
Do you have a guideline to do this ?
Thanks you !
Thanks you !
