Stuck on difficult string conversion (C inside) to integer problem
Pigi_102
Member level 2
Member level 2
Stucked on studid string conversion ( C inside )
Hi all,
I'm facing a stupid problem on converting from string to integer.
I have a string ( like "123" ) and need to interpreter his value, char by char reading backword and looking up his display value in an array ( to lit a 7 segment display by using a 4094 driver.
I already have a code working in C on my linux machine, and a working code for a really old Pic C compiler, but translating in CCS it does not work.
Here some snippet:
char digit[10]=
0b01111110,   // 0
0b00010010,   // 1
0b10111100,   // 2
0b10110110,   // 3
0b11010010,   // 4
0b11100110,   // 5
0b11001110,   // 6
0b00110010,   // 7
0b11111110,   // 8
0b11110010    // 9
void display(char * content, int howmany){
char Bytem;
char p[2];
    while ( (howmany+1) > 0 ) {                         // for every byte in buffer
           p[0] = content[howmany--];                    // read from last char in string backword
           p[1] = '\0';
           Bytem = digit[atoi(p)];
/* here the 4094 routine */
void main () {
   while ( 1 )
     display ( "123", 3);
     display ( "456", 3);
// and so on
In the previous code I had:
int i=0;
           i = (char) content[howmany--] - 0x80;
           Bytem = digit[i];
and was working, but in CCS it does not.
In linux the code is almost the same :
           i = (char) content[howmany--] - '0';
           Bytem = digit[i];
Can you help me understand what I'm doing wrong ?
Thanks
Pigi
Re: Stucked on studid string conversion ( C inside )
I can't see why it shouldn't work but it isn't the most efficient way to program it.
Try changing removing 'howmany' from the declaration and function call and use "howmany = sizeof(content)" instead, it will let you use any length of string without specifying it explicitly.
Also, if the characters are 0-9, change "bytem = digit[atoi(p)]" to "bytem = digit[content[howmany] - '0'];"
Brian.
Try this:
[COLOR="#FF0000"]unsigned char [/COLOR]digit[10]=
0b01111110,   // 0
0b00010010,   // 1
0b10111100,   // 2
0b10110110,   // 3
0b11010010,   // 4
0b11100110,   // 5
0b11001110,   // 6
0b00110010,   // 7
0b11111110,   // 8
0b11110010    // 9
[COLOR="#FF0000"]unsigned char Bytem;[/COLOR]
    while ([COLOR="#FF0000"]howmany[/COLOR]) {                         // for every byte in buffer
           [COLOR="#FF0000"]Bytem = digit[content[[SIZE=3]--howmany[/SIZE]] - '0']; [/COLOR]
void main () {
[COLOR="#FF0000"]   char x[4] = "123";
[/COLOR]   while ( 1 ){
     [COLOR="#FF0000"]display ( x, 3);//or display(x,strlen(x)) or display(x,sizeof(x))[/COLOR]
// and so on
You read the '\0' (NUL) character initialy because you have used post decrement.
So in stead of accessing 3 digits, you access 4 (and the first is an invalid one).
Maybe the code that follows do the trick.
Initially you could replace:
content[howmany--]
with
content[--howmany]
and check if this alone do the trick.
The other red indications are speed optimizations or compiler compatibility hints.
I have tried the suggestion but they ( they are basically the same ) don't work too.
Now my code is:
while ( howmany  ) {           // per ogni byte del buffer
   Bytem=digit[content[--howmanyi] - '0'];
but still no display....
Before you ask, the display code works, as if I do:
while ( howmany ){
   Bytem=digit[howmany];
I get a nice "0" "1" "2" on display.
I'm starting to suspect that the problem could be in some differences in variable dimension or even endianess.
Pigi
What is the mC?
Why don't you debug the code and see what values are used?
I noticed that you rewrite fragment of code here. Maybe some detail that you omit do the problem.
Test the above and see if it works displaying the first digit 3 times
   Bytem = digit[content[0]];
   howmany--;
   display segments here
The compiler is CCS. The micro is a pic 16F84 ( which unfortunally doesn't has icd capabilities ).
If I'm not wrong, being content a char* , if for example content is "123", content[0] is "1" ( in decimal should be 49 ).
Byetm = digit[49] would give unpredictable results ( or a core dump if possible ).
Am I right ?
Pigi
Yes, subtract '0', sorry.
I suspect that because of limited capabilities the "123" you have problem or to the "123" (may be rom array that pointer cannot handle, or the double array usage digits[content[]].
Please zip and post the complete CCS C project with latest code. I will test it in my hardware and reply.
I' m sure, at the moment, that it was a compiler bug.
I have upgraded from 4 to 5 and the same code is now working.
Thanks everyone for the help.
Pigi
