Pat_Mustard
Junior Member level 3
matching layout well proximity effect
Hi
I have been working in layout for a couple of years and I am familiar with a number of techniques for matching devices. As is commonly recomended I try and keep matching devices
- Close to each other
- Orientated in the same direction
- Protected by dummy devices
- Interdigitated / Cross quaded as required
I have recently started in a new position and a number of designers like their diff pairs / current mirrors laid out in different structures to what I'm used to. Using a simple two transistor current mirror as an example commonly I would use abutment to create a tight layout and allow the dummy devices to share the diffusion meaning the 'working devices' were fairly well protected from STI effects (example 1 in picture; poly - red rectanges, diffusion - green rectangles, metal 1 - blue lines, metal 2 - green lines, black spots - contacts).
However some of the designers prefer a structure like 2, where the devices are flipped through 90 degrees, as they feel this allows better current flow (I have no doubt it does). However this structure does not allow the 'working' devices to be protected from STI effects, and although they should all undergo similar ammounts of STI stress due to the dummy devices I dont think this will be a particulary well matched mirror.
I don't want to rule second structure out of hand without doing a bit of research so if the second structure is just as good, or indeed better I would appreciate some feedback. Should you need any further information let us know, we are using a 130nm process, i have been using this for sometime however I believe the designers are used to larger geometries.
Should anyone have any questions please let me know, many thanks
Hi
