[General] Structure Copying Issue in Keil
tdmicro
Newbie level 1
Newbie level 1
hi,
we are trying to copy some data in a structure (IDE :keil , lang - cpp)
structure
typedef unsigned char U8;
typedef struct
	U8 pD;
	U8 sD;
	U8 dD;
	U8* txdata;
}data_ID;
typedef struct
	sObj Data;
	unsigned char ms;
	unsigned char status;
}zmtData;
 typedef struct //autogenerated structure
     ubyte cG;
     ulong uD;
     ulong uk;
     ubyte ubData[8];
     uword cR;
 }sObj;
and the copying function is
Len=4;
 sObj rxData;
	data_ID *dataID = (data_ID *)malloc(sizeof(U8)*(Len+3));// Allocate memory for struct data_ID
	dataID->txdata = (U8*)malloc(sizeof(U8)*Len);
	read_data(&rxData);
 rxData.ubData value is 7,8,9,10,11,12,13,14
	memcpy(dataID,rxData.ubData, sizeof(data_ID));//dataID=(data_ID*)rxData.ubData;
rxData.ubData[] value is 7,8,9,10,11,12,13,14
while copying from rxData.ubData[] to dataID, in watch window, we can see the following details
dataID-> pD= 7;
dataID-> sD= 8;
dataID-> dD= 9;
dataID-> txdata= 00 13 12 11;
but expected value is
dataID. txdata= 13 12 11 10;
while debuging the code, 3rd index value of rxData.ubData 10 is missing. so we thought it is because of structural padding and used #pragma pack(1)
then we are getting exception (classB_trap)
kindly help us to find out the mistake in the above code
You have no understanding of pointers
data_ID *dataID = (data_ID *)malloc(sizeof(data_ID ));// Allocate memory for struct data_ID
After this txdata will still be a undefined pointer and have to be allocated next
