yefj
Advanced Member level 5
Hello,The TGA2590 needs 20V and 6A for proper functionality.In the schematics below its represented as 3Ohm resistor.
however when i need to bias two TGA2590 as shown in the end then my Vss lowers and Current threw it rises.
Which probably means i need to change the gate signal going to the gate of the mosfet or changing the drain voltage going to the mosfet.
Is there a way to take the out of the UCC component that goes as VGS into the mosfter and apply tuning mecahnism so the Vgs could change?
Thanks.
Thanks.
