Strange problem with a Dual Dc-Dc converter
Delta11
Junior Member level 3
Guys I am using a dual dc-dc converter for 12 volts and simulating load through an electronic load. The output voltage reaches its peak value only when a load is connected to the negative side as well. Otherwise even on a minor load, the positive voltage reduced. Looking forward to new ideas.
Are both sides regulated independently? Some converters
"cross regulate" with one of the N outputs being the feedback,
and the rest only "track" to some less-than-perfect extent.
    Delta11
I am trying to find that out now. Thanks for the insight. Been of great use.
Added after 20 minutes:
Can anything be done externally to minimize the effects cross regulation when using dc-dc converters?
