sinoicboy
Newbie level 3
I installed ic5033 on linux as3
i have sever probelms
first in Analog Design Enviroment I can not change or delete the design variable. It seems like the "chang" and "delete" buttons do not work.
and can't modify componet parameters eg nmos's length an width
second
i can edit schematics and symbols
but can't get simulation result
the output log is
Command line:
spectre -env artist5.0.0 +log ../psf/spectre.out +inter=mpsc \
+mpssession=spectre1_7550_9 -format psfbin -raw ../psf \
input.scs
spectre pid = 3550
Loading /home/sino/cadence/ic5033/tools.lnx86/spectre/lib/cmi/2.0/ libinfineon_sh.so
Loading /home/sino/cadence/ic5033/tools.lnx86/spectre/lib/cmi/2.0/libnortel_sh.so
Loading /home/sino/cadence/ic5033/tools.lnx86/spectre/lib/cmi/2.0/libphilips_sh.so
Loading /home/sino/cadence/ic5033/tools.lnx86/spectre/lib/cmi/2.0/libstmodels_sh.so
spectre (ver. 5.0.0.120902 -- 09 Dec 2002).
Simulating `input.scs' on sino at 8:16:16 PM, Tue Jul 17, 2007.
Error found by spectre during hierarchy flattening.
V0: Waveform type must be specified if any waveform parameters are given.
spectre terminated prematurely due to fatal error.
but there is no button in /section / option
third when i insert a p/nmos's layout in a layout virtuoso
the ic50 shutdown suddenly OMG
my .bashrc is
# .bashrc
# User specific aliases and functions
# Source global definitions
export CDSDIR=/home/sino/cadence/ic5033
export CDS_ROOT=/home/sino/cadence/ic5033
export CDS_INST_DIR=/home/sino/cadence/ic5033
export CDS_INSTALL_DIR=/home/sino/cadence/ic5033/tools/dfII
export CDS_LIC_FILE=$CDS_ROOT/share/license/license.dat
export PATH=$CDS_ROOT/tools/bin:$CDS_INSTALL_DIR/bin:$CDS_ROOT/tools/spectre/bin:$PATH
export CDS_Neting_Mode Analog
export LD_ASSUME_KERNEL=2.4.1
if [ -f /etc/bashrc ]; then
. /etc/bashrc
fi
Added after 10 minutes:
Added after 2 minutes:
second
the output log is
Command line:
input.scs
spectre pid = 3550
my .bashrc is
# .bashrc
. /etc/bashrc
fi
