Storing and transmitting char const
hithesh123
Full Member level 6
lax
I am designing a keyboard key emulator.
Each key on the keyboard has a hex code. I can store this in a header file as constants. For example const char A=0x1C;
When I call a function with text string as the passing parameter, I want to transmit the hex codes corresponding to the string characters.
For example, if I call the function trans_string(ABCD)
I want this function to transmit hex codes corresponding to the alphabets A, B , C and D.
OK. When you press A, B, C, D then you want too transmit 0x1C, 0x1D, 0x1E, 0x0F say. You can use UART to send data. trans_string() function will have a switch(key) statement. Depending upon the key pressed it will send the corresponding code for the key stored in a array.
I managed to accomplish that part. But I have new problem now.
The hex codes need to go out bit by bit.
I cannot use any built in functions like UART. I have bit bang.
But don't know how to send each bit of the hex data.
