stm32f030+nokia5110 homemade mini osiloskop
devreci
Junior Member level 1
DIY mini oscilloscope stm32f030+nokia5110
Homemade tiny oscilloscope stm32f030+nokia5110
Not bad. Cheap and you can easily :fight::blah:
View attachment stm32f030f4p6-5510-oscloscpe.rar
67khz
388khz
your initiative is valuable, but I noticed that in attachment, the "main.h" file is missing, could you upload it ? I assume "stm32f0xx_hal.h" belongs to the compiler, so could indicate which one you have used ?
All oscillcospe codes in main.c.
Create project with cubemx "oscilocpe.ioc"
Must copy main.c to project driectory.
Because for small rar file size.
Cubemx project is full of junk files.
Your answer does not clarify the issue.
Then just rephrasing: Put here the contents of the file "main.h"
The cpu .hex file exists in the rarfile.
I don't know why you insisted? Is it forum rule ?
main.h is empty. not code in there. All stm32f0xx...h files standard cubemx hal library.
All the codes are here. 17mb
Main.h
  * File Name          : main.h
  * Description        : This file contains the common defines of the application
  * COPYRIGHT(c) 2018 STMicroelectronics
  * Redistribution and use in source and binary forms, with or without modification,
  * are permitted provided that the following conditions are met:
  *   1. Redistributions of source code must retain the above copyright notice,
  *      this list of conditions and the following disclaimer.
  *   2. Redistributions in binary form must reproduce the above copyright notice,
  *      this list of conditions and the following disclaimer in the documentation
  *      and/or other materials provided with the distribution.
  *   3. Neither the name of STMicroelectronics nor the names of its contributors
  *      may be used to endorse or promote products derived from this software
  *      without specific prior written permission.
  * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
  * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
  * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE
  * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
  * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
  * SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
  * CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
  * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
  * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
/* Define to prevent recursive inclusion -------------------------------------*/
#ifndef __MAIN_H
#define __MAIN_H
  /* Includes ------------------------------------------------------------------*/
/* USER CODE BEGIN Includes */
/* USER CODE END Includes */
/* Private define ------------------------------------------------------------*/
/* USER CODE BEGIN Private defines */
/* USER CODE END Private defines */
#endif /* __MAIN_H */
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
  • ocilocpoe 5110.rar
No, there is no rule that forces one to post an empty source code; however, this is the first time you are mentioning this. By the way, my insistence was only concerned on the usability of the information put here, and once again I thank you very much on behalf of the community for you having shared it
