surendran_raj
Junior Member level 2
Hi.,
I tried to code the bldc controller in sinusoidal waveform. It worked i can able to run the BLDC motor in sinewaveform, when i compare the voltage waveform in any one phase. the pulse waveform was in correct form. when i compare it with phase to phase voltage there wasn't a proper pwm. can anyone help me to solve this issuse.
PWM- timer1 center aligned mode.
phase to phase voltage waveform(green - blue)
