STM32 and SPI Communication Issue
uranyumx
Full Member level 1
Hello,
I want to read data from a custom designed ADC chip through SPI interface. I guess there is an issue about my SPI codes, do you have any feedback on it?
SPI Baudrate: 10 Mbits/s, and the maximum SCLK frequency is 24 MHz
Codes in while loop:
uint16_t ReadADCAmplifier(uint8_t regAddress) {
  uint8_t txBuffer[2];
  uint8_t rxBuffer[2];
  txBuffer[0] = regAddress;
  txBuffer[1] = 0x00;
  HAL_GPIO_WritePin(ADCAmp_SPI2_CS_GPIO_Port, ADCAmp_SPI2_CS_Pin, GPIO_PIN_RESET);
  HAL_SPI_TransmitReceive(&hspi2, txBuffer, rxBuffer, 2, 1000);
  HAL_GPIO_WritePin(ADCAmp_SPI2_CS_GPIO_Port, ADCAmp_SPI2_CS_Pin, GPIO_PIN_SET);
  uint16_t value = ((rxBuffer[0] << 8) | rxBuffer[1]);
  return value;
SPI Settings:
static void MX_SPI2_Init(void)
  /* USER CODE BEGIN SPI2_Init 0 */
  /* USER CODE END SPI2_Init 0 */
  /* USER CODE BEGIN SPI2_Init 1 */
  /* USER CODE END SPI2_Init 1 */
  /* SPI2 parameter configuration*/
  hspi2.Instance = SPI2;
  hspi2.Init.Mode = SPI_MODE_MASTER;
  hspi2.Init.Direction = SPI_DIRECTION_2LINES;
  hspi2.Init.DataSize = SPI_DATASIZE_8BIT;
  hspi2.Init.CLKPolarity = SPI_POLARITY_LOW;
  hspi2.Init.CLKPhase = SPI_PHASE_2EDGE;
  hspi2.Init.NSS = SPI_NSS_SOFT;
  hspi2.Init.BaudRatePrescaler = SPI_BAUDRATEPRESCALER_4;
  hspi2.Init.FirstBit = SPI_FIRSTBIT_MSB;
  hspi2.Init.TIMode = SPI_TIMODE_DISABLE;
  hspi2.Init.CRCCalculation = SPI_CRCCALCULATION_DISABLE;
  hspi2.Init.CRCPolynomial = 10;
  if (HAL_SPI_Init(&hspi2) != HAL_OK)
    Error_Handler();
  /* USER CODE BEGIN SPI2_Init 2 */
  /* USER CODE END SPI2_Init 2 */
Error description is missing. Thus I didn't go deep into code.
One possible issue:
(rxBuffer[0] << 8)
Rxbuffer is 8 bits wide, thus if you shift it 8 bits left it might result in zero.
Better typecast it as 16bit value.
Klaus
Thank you for comments @KlausST !
I modified my codes like that,
uint8_t I_Read8(uint8_t I_address, uint8_t *I_data){
    uint8_t txIBuffer[2] = {(I_address | 0x80), 0x00};
    uint8_t rxIBuffer[2];
    HAL_GPIO_WritePin(I_SPI2_CS_GPIO_Port, I_SPI2_CS_Pin, GPIO_PIN_RESET);
    uint8_t status_I = (HAL_SPI_TransmitReceive(&hspi2, txIBuffer, rxIBuffer, 2, HAL_MAX_DELAY) == HAL_OK);
    HAL_GPIO_WritePin(I_SPI2_CS_GPIO_Port, I_SPI2_CS_Pin, GPIO_PIN_SET);
    *I_data = rxIBuffer[1];
    return status_I;
uint8_t I_Write8(uint8_t I_address, uint8_t I_data){
    uint8_t txIBuffer[2] = {I_address, I_data};
    uint8_t status_I = (HAL_SPI_Transmit(&hspi2, txIBuffer, 2, HAL_MAX_DELAY) == HAL_OK);
    return status_I;
Then to make sure that it works, I call the chip ID which was in register 63
uint8_t I_data ;
I_Read8(63, &I_data);
      HAL_Delay(100);
Then, during the debug session, in the watch window, I got 'error, target not available' message.
--- Updated ---
Update: I got a result which is the attached figure but it should be '2' in decimal based on the datasheet.
