jpdesroc
Newbie level 6
It's been months I'm trying to import a bitmap image
into OrCAD Layout 16.2 without success..
-1rst test: import a DXF file (converted BMP file) into OrCAD layout
problem incountered: The DXF file imports
but I only get the image countours (no fills)
How to get a filled DXF ???
-second test: I downloaded a utility called GIFtoLLB
from a company called Versa Design that converts a GIF (black/white)
image to a OrCAD Layout .LLB library readable by Layout
as a standard library with one footprint inside (the actual translated image)
problem encountered: the GIF image cannot be made
of too many information (like a GIF PCB from a magazine).
Only small GIF image work..
What I'm thinking to do is use another CAD soft
(Eagle, PADS, Protel, etc.) that do import PDF or raster files.
Then I could do an import from the CAD file format into OrCAD Layout 16..
Any working ideas tried ??
Thanks.
J-Pierre
Thanks.
J-Pierre
