PAPAI1
Newbie level 2
SIR,
M TRYING 2 CALCULATE SAR/(POWER ABSORPTION IN THE LAYEARS) OF AN OBJECT WITH MULTI-LAYER ... DUE TO THE RADIATION COMING FROM A FAR FIELD ANTENNA. MY MAIN CONCERN IS THE OBJECT BUT NOT THE ANTENNA.
NOW, I HAVE DEFINED....
1. THE EPSILON R OF EACH LAYER
2. MUE =1
2. MASS DENSITY OF EACH LAYER
WHAT ARE THE OTHER THINGS DO I NEED 2 DEFINE FOR SAR CALCULATION IN CST?
I HV ALSO DEFINED FIELD MONITOR @ DESIRED FREQUENCY & POST-PROCESSING PARAMETER AS SAR/POWER LOSS DENSITY @ 900MHz.
DO I NEED 2 DEFINE THE CONDUCTIVITY ALSO FOR SAR CALCULATION?
A BASE STATION ANTENNA IS RADIATING @ 900 GHz FROM VERY HIGH ALTITUDE & I WANT 2 SEE THE POWER DENSITY/SAR ON THE MULTILAYER OBJECT WITHIN EACH LAYER......
PLEASE, HELP SOON....THIS IS NEED FOR MY M.E. THESIS...HV VERY SHORT TIME IN HAND.......PLEASE,,, PLZ HELP ME SIR...
IF U KINDLY MAIL ME @ papai.papai.1989@gmail.com , it will be much easier 2 access...
2. MUE =1
