Stepper motor Driver with Step-Up converter
htekin42
Member level 2
Member level 2
Dear All,
I will design a step motor driver with TI ic's. I will going to use 12V power supply. but leadshine step motor need 48V. If I make a board with step up converter. Is it suitable or not?
Please make me suggestions.
Thanks
Best Regards.
do you have another option?
I don´t see any as long as you insist on 12V supply and this motor.
BTW:
A stepper should be current driven, therefore the motor voltage will adjust.
If you don´t need full speed or don´t need full torque you may use reduced supply voltage.
Klaus
