kanni1303
Full Member level 3
- Joined
- Jun 29, 2012
- Messages
- 164
- Helped
- 12
- Reputation
- 24
- Reaction score
- 11
- Trophy points
- 1,298
- Location
- Chennai, Tamil Nadu, India
- Activity points
- 2,716
I tried to run my 4 wire bipolar stepper motor with PIC16F877A and L293D driver... but the problem is without any connection to **broken link removed** I get output on all the pins and this makes motor not to rotate... then I checked only 293D **broken link removed** with ordinary dc motor the problem exist again... without anything I connected 5V supply to pin 1,8,9,16 and pin 4,5,12,13 to ground I got 5v across pin 2,3,6,7,10,11,14,15 to gnd... I don’t know what may be problem, where I get these voltages I think there is strong isolation between input pin and output pin and gnd... I tried if there is any internal short but except the ground pins no short was found and it measured 14M ohms across output to gnd... Without giving logic on input the output goes to logic high what may be the problem
