mahen
Newbie level 3
Hi Guy,
The product that I'm handling is using a buck DC DC Converter, whereby the output will be around 13.8 V and the input is able to vary from 11V to 26V. The prodcut was soaked in the temperature chamber whereby it goes thru a temperature cycle from +85C to -45C for 2 days which is part of the test profile and was found to have the switching transistor (PNP) burnt.
Could anyone tell me what could have caused the problem. The voltage used at that time was 17V and it normally drains around 3A but we found out that the current went up to 14A before the transistor got burnt.
What are the potiential causes of the transistor to get burnt?
