static timing analysis & its modes
veenashree89
Member level 2
Member level 2
BANGALORE
hi all.....
I am new to STA...i just want to know.,wat are are the modes need to be cleared in sta..and at which stage of ASIC design we perform different modes of STA..please suggest some links to know more about this...
Input to an STA tool (primetime) is a netlist (Verilog , VHDL ,EDIF) , delay formats , library formats . STA is performed at pre-layout n again at post-layout stages. It is performed to check whether your design meets setup n hold specifications or not n other spec. like input delay , transition , output delay as per your design specifications. and lot of other things.
Get more info here "Timing Paths" : Static Timing Analysis (STA) basic (Part 1) |VLSI Concepts
sta modes are nothing but the way you apply the constraints, depending upon the mode, generally variation in the case analysis of the ports will create the modes
