static function in c language
selva murugesan
Full Member level 1
hello
Can any one explain me about static function in c with example?
I've already seen that , anything else with some depth explanation
I will quote you a simple example !
observe the code with and with out static,
#include<stido.h>
void foo(void)
    // int a = 10;
    static int a = 10;
    a++;
    printf("%d\n",a);
int main()
	foo();
    foo();
hi friend
I appreciate your previous work.but, my friend I would like to inform you that is static variable explanation. I knew it already. I want to know something about static function.
I have some basic idea about that function, i tried in my code blocks complier. the way of working is some what differ from what I knew the same.
When a function is declared as a Static function, it limits the scope of that function to the c file it is in.
So when a program is made up of several linked c files, the function can not be seen or called from the other c files.
So it is used to limit the scope of a function. (to avoid name clashes amongst other things)
