starting with Dspic 30f4013 , need help
malik_123
Member level 4
Member level 4
i use CCS compiler of PIC series controllers.
what u guys suggest , can i use the same compiler for Dspic as well. or i need to switch to the Mplab ?
You can use the same compiler (all depending on which CCS complier and version you are using)...
