Start up voltage of Atmel SAM3N00B microcontroller?
T
treez
What is the minimum vcc voltage at which all Atmel SAM3N00B microcontroller parts from any production batch can be gauranteed to start up?
Page 696 of the datasheet appears to say that the SAM3N00B may start up at any voltage between 1.62V and 3.6V..-but is it garanteed to start up at 1.62V?
SAM3N00B microcontroller datasheet
http://www.atmel.com/Images/doc11011.pdf
Never worked with ATMEL Cortex-M3 core, but the answer would be the same even if I was using it. If there is no errata sheet or something (which is difficult since we are talking about supply voltage range) to claim the opposite, I find no reason why it is not guaranteed. Have you noticed something different?
Reactions: treez
    T
