HvEdtg83
Newbie level 3
I'm trying to figure the easiest way to wire up a R2D2 cake we are making for my nephew. The electronics would be worked into the cake and insulated from it.
I would like to have a button that he can push which would simultaneously trigger a red LED (mounted in a bezel) and initiate a 9V sound recording module (from Radioshack) that I would use beforehand to record the R2D2 sound effect from one of the movies.
Ideally the red LED would come on and stay on, and the recording module would play back only once unless the button was pressed again.
I'm thinking it can be done with
- battery + battery holder
- recording module
- resistor
- red LED + bezel
- on/off push button
Would it be possible for me to wire up the recording module as normal and simply insert the LED portion of the circuit in between the battery and the recording module?
Any advice is appreciated
- recording module
- resistor
- red LED + bezel
