standard cell library design
nikita gupta
Newbie level 3
Newbie level 3
I am designing TSMC 0.35um standard cell library for my college project. i have designed basic logic gates with minimum W and L. How can i design these for different driving strength and so how layout will change.
Now i am also trying to make Latch so plz suggest me helpfull links and material.
high drivability is a product of paralell connection of gates. For layout, you place 2 cells side by side and connect the poly, and then either connect output metals or share the output diffusion if you can.
nikita gupta,
Design a basic cell 0f 1X drive as per your spec, and for higher drives jus multiply with drive.
For Ex : 1X Inverter L- 0.35.. Wn - 0.5 Wp - 1.2 Derrive 2x from 1X.. For 2x L - same Wn -1 and Wp - 2.4
nikita gupta,
exactly....2X=2 * 1x cells shared together to save area and reduce leakage
