[SOLVED] Stages involved in compling a program
nirmala h
Member level 1
Member level 1
Bangalore, India
Hi All,
Could anyone tell me clearly what are all the steps involved in compling this simple program(each & every steps).
#include<stdio.h>
main()
printf("Hello");
Here is a good link
1.h**p://www.acm.uiuc.edu/sigmil/RevEng/ch02.html
2.h**p://www.personal.kent.edu/~rmuhamma/Compilers/compiler.html
Hi
There are 5 stages of compilation in C program
1. pre-processing
2. compiling
3. Assembling
4. Linking
5. Loading
At pre-processing stage mainly the compiler does three things they are including source code of headers, comment deletion, macro substitution...
At compiling stage the compiler converts source code into assembly code
At assembling stage the compiler converts assembly code to machine code
At linking stage links the different object files into single file
finally at loading stage the executable file moves to into memory....
You can clearly see this all using GCC compiler
the commands are 1. pre-processing------>gcc -E file.c> file.i
2. Compiling-----------> gcc -S file.c>file.s
3.Assembling---------->gcc -c file.c
this is the compilation process
If you have any additional questions concerning ANSI C or Embedded C, you may want to checkout the group:
Embedded C/C++ Programming
I have posted numerous links to C tutorials, C compilers and sample projects and while the group was specifically setup for C development in Embedded Systems, there are plenty of material for ANSI C.
BigDog
