gres
Full Member level 4
Assumptions
Small dimensions, high SPL, packs doesn’t have to play basses that can shake to walls, Angle lower than 45*, “pro” finishing.
Casing
Project for Turbo sound listeners, some dimensions are different but angle of depression is the same – that means 35*. Casing made of leaf- splice, waterproof, with 12mm thin. I used glue and screws. Spatula finishing, painted with nitromal. Steal on front. At bottom side are 2 speakon neutrik slots and two runners. Casing is 30-40 liters capacity, and is tuned for +-40Hz. Why more or less? Casing should be as small as is possible, but with capacity fit to 2 speakers 12” that don’t play with low bass. Tune is set to get nice sound without noising.
Speakers
x GDN-30-400-8-se STX-a i driver D220ti Selenium
Branch
I counted it on calculator, and temporary board.
Impressions
I couldn’t check them at house couse I don’t have enough amplifier and I don’t have time for that. So first live. You can watch/ hear at https://www.youtube.com/watch?v=anGmvreJNDQ What can i say? Assumptions done in 100%. It play well and SPL very high. It also looks very nice at stage.
Original text at https://www.elektroda.pl/rtvforum/v...rk=topic&sid=7bf33dea98ad8f18ba035a41a9efeeec
