STA --> Constraining IOs for High Speed Serial Interface (HSI)
Esteban13
Newbie level 2
Newbie level 2
Hi;
could you please help me understanding how to define STA constraints on IOs for an HSI interface ?
What are the important path to checks; especially for the receiving part ?
Thank you in advance
Regards
Esteban,
You can set up set_input_delay and set_output_delays for your synthesis tools. For Highspeed designs, setting max/min values have had best results . . .
# Constrain the input I/O path
set_input_delay -clock clk -max 3 [all_inputs]
set_input_delay -clock clk -min 2 [all_inputs]
# Constrain the output I/O path
set_output_delay -clock clk 2 [all_outputs] 2
However, you may need to experiment with these . .
-- adam
Adam;
many thanks for your answer.
BtW; my question was more interface oriented.
My point was to better understand what are the importants parts to check linked to an HSI interface.
Best Regards
