[STA] Back annotation on the separate modules [SDF]
ivlsi
Advanced Member level 3
Hello All,
As for the SDF file, which designers get from the Layout team and run STA checks on their modules, is it a common for all the chip. I mean, should each designer take a big SDF file for the whole chip for just running STA checks on its small module?
Could the full-chip SDF be divided to the smaller parts, so each designer will back annotate only gates and nets from the module on which he/she run STA checks?
Hopefully you got my point...
Thank you!
whole chip sdf is a must, i think.
a) if you only checked submodules, how about the interface between the modules.
b) did you take a look at the final layout netlist? it changed a lot, some high fanout pins, clk trees ,some pass through buffers and etc.
how to deal with that.
i think sdf for all chip is a must.
Reactions: ivlsi
    ivlsi
As for the layout SDF, could it be written out just for some hierarchies or chip regions? Is it useful?
