Mastermind_rocks
Newbie
Hello Folks,
I am trying to initialize and use the TFT-Display module ST7272A using LTDC driver of STM32H743 microcontroller.
I am newbie for TFT-Display. I do not know the command and sequence in which data has to be sent using SPI and RGB lines to TFT display.
Please help me in understanding how to make this work.
Attaching the snip of lwip initialization using LTDC driver of STM32H743.
Note: Please note that the above development is to be done on custom hardware.
Let me know if i am missing anything.
[moderator action: added code tags]
void ltdc_init()
// enable ltdc clock
__HAL_RCC_LTDC_CLK_ENABLE();
// __HAL_RCC_DSI_CLK_ENABLE();
__HAL_RCC_WWDG1_CLK_ENABLE();
const int h_sync = 4;
const int h_back_porch = 43;
const int h_active = 320;
const int h_front_porch = 8;
const int v_sync = 4;
const int v_back_porch = 12;
const int v_active = 240;
const int v_front_porch = 2;
// configure the panel timings and signal polarity
LTDC->GCR &= ~LTDC_GCR_PCPOL; // synch signal polarity setting
// hsync and vsync
LTDC->SSCR = ((h_sync - 1) << 16) | (v_sync - 1);
// accumulated horizonal and vertical back porch
LTDC->BPCR = ((h_sync + h_back_porch - 1) << 16) | (v_sync + v_back_porch - 1);
// accumulated active width and height
LTDC->AWCR = ((h_sync + h_back_porch + h_active - 1) << 16) | (v_sync + v_back_porch + v_active - 1);
// accumulated total width and height
LTDC->TWCR = ((h_sync + h_back_porch + h_active + h_front_porch - 1) << 16) | (v_sync + v_back_porch + v_active + v_front_porch - 1);
// enable ltdc transfer and fifo underrun error interrupts
// LTDC->IER = LTDC_IT_TE | LTDC_IT_FU;
// configure ltdc layer
LTDC_Layer1->WHPCR &= ~(LTDC_LxWHPCR_WHSTPOS | LTDC_LxWHPCR_WHSPPOS);
LTDC_Layer1->WHPCR = ((0 + ((LTDC->BPCR & LTDC_BPCR_AHBP) >> 16U) + 1U) | ((320 + ((LTDC->BPCR & LTDC_BPCR_AHBP) >> 16U)) << 16U));
LTDC_Layer1->WVPCR &= ~(LTDC_LxWVPCR_WVSTPOS | LTDC_LxWVPCR_WVSPPOS);
LTDC_Layer1->WVPCR = ((0 + (LTDC->BPCR & LTDC_BPCR_AVBP) + 1U) | ((240 + (LTDC->BPCR & LTDC_BPCR_AVBP)) << 16U));
LTDC_Layer1->PFCR = LTDC_PIXEL_FORMAT_RGB565;
LTDC_Layer1->DCCR = 0x000000FF; // layer default color (back, 100% alpha)
LTDC_Layer1->CFBAR = (uint32_t)&__ltdc_start; // frame buffer start address
LTDC_Layer1->CFBLR = ((320 * 2) << LTDC_LxCFBLR_CFBP_Pos) | (((320 * 2) + 7) << LTDC_LxCFBLR_CFBLL_Pos); // frame buffer line length and pitch
LTDC_Layer1->CFBLNR = 240; // line count
LTDC_Layer1->CACR = 255; // alpha
LTDC_Layer1->CR |= LTDC_LxCR_LEN; // enable layer
// reload shadow registers
LTDC->SRCR = 0;//LTDC_SRCR_IMR;
// enable LTDC
LTDC->GCR |= LTDC_GCR_LTDCEN;
LTDC->BCCR = 0x000000FF;
