SR flip flop design in Ltspice
rahul.6sept
Full Member level 5
Full Member level 5
Guwahati, India
I'm trying to design a clocked SR flip-flop in Ltspice with a pulsed voltage source. I set the time step 100 ms. When I run it gives an error "Time step too small". I increased the time step but it does not solve the issue. Please advice me a solution to it. Attached herewith my circuit.
  • SR Flip Flop.rar
What are you calling a "clocked SR"? Those don't really go together. A JK FF is sorta like that. A SR FF is asynchronous.
100ms is pretty large for low voltage logic (and about anything else) as a.timestep.
Bistable logic wants an initialization. The "R" state asserted at DC maybe. But by im0osing a clock you may defeat any reset unless an async reset path is added.
Wrong circuit. A2 and A4 have inverting feedback. What do you try to achieve?
--- Updated ---
Guess you want to model a gated SR latch:
Problem is that it needs an initial condition for the output latch, also it doesn't handle the input condition S=1 and R=1 which causes an undefined output in real hardware.
--- Updated ---
You can overcome the RS latch race condition by introducing a small asymmetry, e.g. adding a pF load capacitance to one of the outputs.
--- Updated ---
  • sr_ff1.zip
  • sr_ff2.zip
