KerimF
Advanced Member level 5
- Joined
- May 17, 2011
- Messages
- 1,554
- Helped
- 376
- Reputation
- 760
- Reaction score
- 379
- Trophy points
- 1,373
- Location
- Aleppo city - Syria
- Activity points
- 13,095
If one searched the expression ‘Raised Cosine’, he would likely find that it is related to special filters, called Raised Cosine ones. These filters smooth the fast rise and fall edges of a squarewave signal to remove its higher harmonies.
Once, I needed this transformation. I solved it, to a good approximation, without adding a raised cosine filter.
In case a member may be interested in this too, I attached below, ‘RaisedCosine_01.zip’ which is a basic circuit of it.
For instance, I simply got its main idea from an old analogue generator IC, XR-2206, which generates square, triangular and sine waves (<400 KHz).
