SPWM duty cycle update using CCP1 & TMR1 in pic16C73
codemaster11
Full Member level 1
const unsigned char sine_table [73] = {0, 6, 12, 18, 24, 29, 31, 35, 41, 46, 52, 57, 63, 68, 73, 78, 83,
87, 92, 96, 100, 104, 108, 112, 115, 118, 121, 124, 126, 128, 130, 132, 133, 136, 136, 137,
137, 136, 135, 134, 133, 131, 129, 127, 125, 123, 120, 117, 114, 110, 107, 103, 99, 94, 90, 86, 81,
76, 71, 66, 61, 55, 50, 44, 38, 33, 27, 21, 15, 9, 3, 0};
int duty = 0;
bit P1M1_invert;
float feedback = 1.00; //max dutycycle.----->Duty cycle = 100%
int k = 0; unsigned int ac_volt = 0;
float vAD = 0.0;
void InitTimer1(){
T1CON = 0x01;
TMR1IF_bit = 0;
TMR1H = 0xFD;
TMR1L = 0xE8;
TMR1IE_bit = 1;
INTCON = 0xC0;
void Interrupt () iv 0x0004 ics ICS_AUTO {
if(TMR1IF_bit) //timer1 overflow ---> 134usec.
TMR1IF_bit = 0;
TMR1H = 0xFD;
TMR1L = 0xE8;
duty++;
if(duty >= 73)
duty = 0;
P1M1_invert = ~P1M1_invert;
//CCPR1L = 0;
asm nop;
asm nop;
if(P1M1_invert)
RC0_bit = 1;
RC1_bit = 1;
RC3_bit = 0;
RC4_bit = 0;
PWM1_Set_Duty(sine_table[duty]);
else
RC0_bit = 0;
RC1_bit = 0;
RC3_bit = 1;
RC4_bit = 1;
void main()
//configure analog channle 4.
TRISC = 0;
PORTC = 0;
PWM1_Init(20000);//initialize at 20KHz
PWM1_Start();
InitTimer1();
//duty = 0;
while(1)
//feedback control code flow.
above mikroC code generate SPWM using only CCP1 with "7408 AND gate ic " making it to work as two CCP.
TMR1 is use to generate 50Hz setting XTAL = 16MHz with interrupt overflow 134usec. here the simulation show 49 or 50Hz fine with
sine_table of 73 values . here a problem of how to update SPWM duty cycle using a variable resistor at analog pin?
Change each and every value in your data table by some percentage (longer or shorter). Realistically you'll multiply every value by some coefficient just before you send a pulse to your output stage.
You probably wish to dial the variable resistor (potentiometer) to change a voltage setting somewhere. Read this voltage and convert it mathematically to a usable coefficient.
PWM1_Set_Duty(sine_table[duty] x coefficient); <--------- you say to write it as. i tried this method by putting a constant value to check whether
it is changing duty cycle or not but another problem arise that is sine wave frequency drooped to about 10Hz from 50Hz in Proteus simulation by putting
constant value like this PWM1_Set_Duty(sine_table[duty] x 0.8 );
An oscilloscope can confirm what's causing the slowdown, whether it's a result of hardware function or of code execution. If it happened to me I'd think I was packing too many calculations in each cycle.
It could be a matter of reducing the number of samples per cycle.
Or taking up some cpu cycles to calculate updated duty values and write them into memory just once.
Or scraping for any and every shortcut that lets you hold to your desired 50 Hz.
Sorry I have no hands-on experience with mikroC.
LaTeX Commands Quick-Menu:
