xihuwang
Member level 2
spur and phase noise ?
Hi:
Dose anyone know wheather phase noise is included in the phase noise
simulation result in spectre ? I saw a peak at the freqeucy of (fo - fm) .
The second question is wheather should I include the reference spur
when calculate or simulate the peak long and short term jitter peak ?
My last question is how to calculate or simulate using specte the jitter
or phase noise if spur must be considered .
I saw many papers and IP core of pll frequency synthesizer give
long term and short term jitter or phase noise. But I think it is not
right because I think phase noise is the result of device randon noise.
And I think for frequency synthesizer it is the frequency jitter ,but not
the phase jitter dose matter.
I am totally confused with spur , phase noise , jitter ( cycle-to cycle, period-to-period
...jitter ) when design a pll frequency synthesizer.
I get the eye diagram in spectre, and I find the jitter is small for good charge pump
but large jitter for bad charge pump . How to explain it . Does it has meaning to
see the eye diagram for frequency synthesizer I I think the phase jitter does
not matter for frequency synthesizer which just need to output period stability
clock signal)
Thanks forward and need your help !
Best Regards!
Hi:
clock signal)
Best Regards!
