jimjim2k
Advanced Member level 3
download mips r2000 simulator
Hi
spim is a self-contained simulator for running MIPS R2000/R3000 assembly language programs. It reads and immediately executes assembly language code for this processor. spim provides a simple debugger and simple set of operating system services.
spim implements almost the entire MIPS assembler-extended instruction set for the R2000/R3000 (It omits some of the complex floating point comparisons and details of the memory system page tables.) The MIPS architecture has evolved considerably since then (in particular, from 32 to 64 bits), which means that spim will not run programs compiled for recent MIPS or SGI processors.
spim comes with complete source code and documentation. It also include a torture test to verify a port to a new machine.
spim implements both a simple, terminal-style interface and a visual windowing interface. On Unix, the spim program provides a terminal interface and the xspim program provides an X window interface. On PCs, the spim program provides a DOS interface or console interface and PCSpim provides a Windows interface..
1. h**p://www.cs.wisc.edu/~larus/spim.html
* -> t
tnx
Hi
* -> t
tnx
