SPI using 89c51ED2 - help needed
aniket4eda
Newbie level 3
Newbie level 3
SPI using 89c51ED2
Hi friends,
I am using 89c51ED2 in my app. It is configured as a master and I'm trying to use on chip SPI to communicate with the ADE7758. As given in the data sheet of ED2 I've configured the interrupt for the SPI. It's generating the interrupt but the communication is not starting. I've also checked the signals SCLK, MISO, MOSI on the CRO but it's not giving any signals. Please help me as early as possible.
Re: SPI using 89c51ED2
How can someone help you troubleshoot your problem if you do not post your code?
sorry..
Here's the code I've used.
I am using the KEIL uVision 3 IDE. I've also checked whether the SPI interrupt is coming or not? it's giving the interrupt.
//dsp7758.c
#pragma NOAREGS
void ReadDSP7758(unsigned char address, unsigned char length)
idata unsigned char index=0x00;
SPIStart();
SPIWrite(address);
HOLD
while(index<length)
SPIBUF[index]=SPIRead();
index++;
HOLD
SPIStop();
#pragma AREGS
#pragma NOAREGS
void WriteDSP7758(unsigned char address, unsigned char length)
SPIStart();
SPIWrite(address);
HOLD
while(index<length)
SPIWrite(SPIBUF[index]);
index++;
HOLD
SPIStop();
#pragma AREGS
//spi.c
unsigned char serial_data;
bit transmit_completed= 0;
unsigned char SPIBUF[3];
xdata unsigned char temp_value;
void it_SPI(void) interrupt 9 using 1 /* interrupt address is 0x004B */
switch ( SPSTA ) /* read and clear spi status register */
case 0x80:
serial_data=SPDAT; /* read receive data */
transmit_completed=1;/* set software flag */
temp_value++;
break;
case 0x10:
/* put here for mode fault tasking */
temp_value=0;
break;
case 0x40:
/* put here for overrun tasking */
temp_value=0;
break;
//#pragma AREGS
void SPIStart()
SPCON |= 0x10; /* Master mode */
P1_1=1; /* enable master */
//SPCON |= 0x82; /* Fclk Periph/128 */
SPCON |= 0x81; /* Fclk Periph/64 */
SPCON &= ~0x08; /* CPOL=0; transmit mode example */
SPCON |= 0x04; /* CPHA=1; transmit mode example */
IEN1 |= 0x04; /* enable spi interrupt */
SPCON |= 0x40; /* run spi */
EA=1; /* enable interrupts */
CS=0; //Chip Select of ADE7758
void SPIStop()
CS=1;
SPCON &= ~0x40; /* stop spi */
#pragma AREGS
void SPIWrite(unsigned char spidata)
SPDAT=spidata; /* send an example data */
while(!transmit_completed);/* wait end of transmition */
transmit_completed = 0; /* clear software transfert flag */
#pragma AREGS
#pragma NOAREGS
unsigned char SPIRead()
SPDAT=0x00; /* data is send to generate SCK signal */
//data_save = serial_data; /* save receive data */
return serial_data; /* save receive data */
#pragma AREGS
//main.c
void main()
SPIBUF[0]=0x40;
WriteDSP7758(WR_APHASE,1);
while(1)
ReadDSP7758(RD_WAVMODE,1);
test_value=SPIBUF[0];
DisplayPage(); //displays value of WAVMODE and also the
// temp_value which is incremented in the SPI interrupt
