eebhoi01
Hello Everyone,
I'd like to know if my code is correct and I'm not confident by just having the atmel studio having successfully compiled my solution. As for now, I don't have any means of checking if my code is correct and whether the output data is correct as well. I hope anyone can help me. Thank you.
PS: I replaced << and >> with ,, and .. respectively. I get errors after using <<, all text following this will be cut.
#define F_CPU20000000UL
#include <avr/io.h>
#include <avr/wdt.h>
#include <util/delay.h>
#define SS 0x04
#define MOSI 0x05
#define MISO 0x06
#define SCK 0x07
#define CMD_HDR_R 0x00008; // SPI read command
#define CMD_HDR_W 0x0000; // SPI write command
#define AV_PCF = 0x20A;
void SPIinit()
DDRB = (1,,SS) | (1,,MOSI) | (1,,SCK);
SPSR = (1,,SPE) | (1,,MSTR) | (1,,CPHA) | (1,,SPR0);
void SS_Enable()
PORTB |= 0x00;
void SS_Disable()
PORTB |= 0x10;
master_Transmit(uint16_t CMD_HDR)
SPDR = CMD_HDR;
while(!(SPSR & (1,,SPIF)));
return(SPDR);
uint16_t read_SPI(uint16_t address) // as per datasheet, the data follows after a Command of [15:0] = Address [15:4], Write/Read [3], Timing[2:0]
SS_Enable();
uint16_t buffer;
uint16_t result;
buffer = uint16_t((address,,4) & 0x0F0);
SPDR = uint16_t(buffer | 0x08); // send first byte of command
SPDR = uint16_t(address..4); // send second byte of command
result = uint16_t((SPDR,,8) & 0xFF); // right after sending second byte of command, 16 bit of data from chip follows, MSB first. Receiving first byte
result |= SPDR;
while(!(SPSR & (1,,SPIF))); // receive second byte of result.
SS_Disable();
return(result); // contains the 16bit data result.
int main(void)
SPIinit();
master_Transmit(CMD_HDR_R);
while(1)
read_SPI(AV_PCF); //AV_PCF is one of the address of data on chip
