Spectre==SpectreRF in Cadence?
knack
Member level 2
Member level 2
Austria
In Cadence ADE window,
When selecting the simulation host, i can't see "SpectreRF" named simulator !!!
Only "Spectre" and "SpectreS" .. Which or where's "SpectreRF" ??
Is it one of them??
No? Well, how to include in simulator lists??
You're great forum members indeed!
Sure someone will answer with help!
Cheers,
-- Knack
Is it one of them??
Cheers,
-- Knack
When you run PSS, PAC, PNoise, etc, you are using SpectreRF. You can obtain more info by looking at cadence documentation.
    knack
Wow!!
Thank you for prompted reply!!! :)
I willl look for it in cadence docs, but there're many.. which one certainly?
Cheers,
--Knack
Is it one of them??
Cheers,
-- Knack
SpectreRF user guides
    knack
You can find it under the path: $CDS_ROOT/docs/spectreRF/spectreRF.pdf
(where $CDS_ROOT refers to your Cadence installation directory)
Read it in page 245, you will find that Spectre simulator include SpectreRF simulations to run as stated above...
Regards,
Ahmad,
    knack
spectreRF is not a single simulator. it's actually spectre but more feature are added specifically in aid of RF analysis. so just like how you set up spectre analysis but choose the analyses you need, such as pss, pnoise, etc.
