Specifications for sending SMS via PSTN
davorin
Advanced Member level 3
Switzerland
PSTN SMS Specs
Hello...
Has anybody seen specifications or even better an application note describing how to use the SMS service for fixed-lines (PSTN) phones?
Like how the receiver/sender side could be built....
thx in advance
/davorin
PSTN SMS Specs
is this isdn you are talking about, which could supports outband information sent to user ? I mean there is no way for POTS . Or are you trying to design such?
There are some brief isdn capabilities mentioned :
Re: PSTN SMS Specs
No..there is this service here for SMS over POTS...you just dial the POTS SMSC number and you hear then some strange "beeps" (o;
I guess the reception of SMS for POTS phones is similar to CallerID over POTS...
PSTN SMS Specs
So most probably you are about :
https://www.intel.com/business/bss/solutions/blueprints/pdf/bharti_telesoft_sb.pdf
or
I think if we are talking about POTS line subscriber interaction principles - that is implementation specific. Probably use ineraction IVR builtin logic done in fixed or Parlay or IN way.
To put some specific signalling they should produce a special terminals to interact with fix line SMSC.
I assume that your question is general as you did not mention specific operator or service example.
