Specctra autoroute single side whit autojumpers
MCMC
Full Member level 1
specctra autoroute
Hi all :(
I need help !!!
How to set the rules (Layers) and do file to make single side pcb whit Horizontal & Vertical autojumpers in specctra ?
please helpme !!
specctra set jumpers
To set only one layer its easy, but make autojumpers...I'm looking to, but think that is not possible
HH
NeuralC
software place jumpers autoroute
First open specctra design file and then:
1. Define top layer as jumper layer
---(layer TOP(type jumper)----
2. Define jumper length
---(jumper (length 400))--- Insert this row just before PADSTACK section
And you have autorouting with jumpers.
Reactions: Artym
    Artym
autoroute single side pcb
Hi borisov57,
Can you be more clear?
HH
NeuralC
pcb autorout single side
Yes,
1.Open specctra design file in notepad
2. Press control+F( find ), type padstack
3.Insert "(jumper (length 400))" a row before padstack section begin.
That will told specctra, which jumper length to use.
I hope this helps. You can choose differnet jumper lengths and you can have more than one jumper defined.
Reactions: Artym
    Artym
specctra jumpers
i have seen spectra often hang out durring the routing can any one suggest the reason why
