ahgu
Full Member level 3
What are the ways to reduce noise on the speaker?
I have white noise from my speaker from otuput of the codec, even outputting zero.
My setup:
DAC---> differential output --> 10X power amplifier(bridged connection).
From some measurement, I found the noise from the DAC is higher than the ground even though it outputs 0.
Also, there is noise in the circuit that contribute the the speaker before 10X gain.
I measure the AC voltage across the some points. I don't know how to measure the noise, measuring AC voltage using a 6.5digit DMM is the only way I can think of.
Regulator: 0.4mV
DAC output at 0: 0.8mV.
Input to the power amplifier is min 0.4mv even if DAC is removed.
With these combination, I hear white noise from the speaker.
Now how can I remove the white noise? This seems a tough problem.
My setup:
Regulator: 0.4mV
