SPC5 studio programming problem
rezaf
Full Member level 1
Montagram
Hello. I'm working with SPC560 series MCU from ST company and SPC5 studio compiler. for getting started, I'm working on a simple LED blinking program but when I program my hex file to MCU, the MCU takes high current and damaging (about 300mA).
working with SPC5 Studio is hard and complex because work on Eclipse platform. if you know any other compiler that supports this series of MCU please help me.
I don't think it's a compiler problem when the microcontroller takes 300 mA.
I rather think there is a hardware problem.
Klaus
If you need further help, show your code and hardware.
Klaus
I checked this on two correct board that with erasing the MCU, the current go down but after programming it, the current go up!
I written the code with SPC5 studio that have a poor support and based on Eclipse. this compiler have some ready component that I don't see the generated codes and only can edit main.c . in this compiler there is a graphical pinmap editor and clock editor and each function of MCU have ready library, so copying my main.c code will not help you. may be there is a bug in libraries.
All this text is useless as long as you don't show code and schematic...
Klaus
