System.out
Member level 4
![Member level 4](/styles/images/ranks/dlevel4.gif)
Hello,
I had built the schematic on the application note XAPP453, pg 8. I could program FPGA, also PROM, but when i did not have the JTAG attached to the board, the PROM was unable to download the bitcode to the FPGA.
Now, i need to fix this issue and i am looking to different circuits, which makes me confused:
:arrow: XAPP453, pg 8
https://www.xilinx.com/support/documentation/application_notes/xapp453.pdf
M{0,1,2} are attched to GND
PROG_B, DONE signal has a pull-up to 2.5V
TMS, TCK, TDI (PROM) are feed directly from JTAG, instead doing so after Rser
3.3V JTAG Port pin names are missing
:arrow: UG332, pg 82
https://www.xilinx.com/support/documentation/user_guides/ug332.pdf
Let's assume we want 3.3V JTAG voltage, the PROG_B and DONE pull-up are to 3.3V (V)
/CF (PROM) looks like an input feeded by /PROGRAM signal, while previous schematic shows /CF as an output. (Where does this /PROGRAM signal come from?)
:arrow: Digilent S3 Board, sheet 4/8
Looks like TCK, TMS, .. are feeded aftr Rser (100ohm and not 68ohm as datasheet states)
There are many other differences to previous schematics
So, the question is if I would like to have an FPGA and a Flash PROM working nicely (program FPGA from the PROM; use boundary scan; ...) which is the best schematic to work with? Maybe do you have a circuit schematic that you know it works for this topic?
Kind regards
Kind regards
