knicklicht
Junior Member level 1
Hello all,
I am currently trying to get the verilog-ethernet project (https://github.com/alexforencich/verilog-ethernet) to run on my Spartan 6 xc6slx16. My PHY is connected via RGMII and the MAC uses two 125MHz clocks 90 degrees out of phase. As an input I have a 25Mhz clock. While there is a sample project for RGMII it uses a Virtex 6 and MMCM which is not available on the Spartan.
I have tried using a PLL to generate the two clocks but I don't get a response from the board when sending a UDP message. Assuming that I didn't make a mistake elsewhere could the PLL be the issue and do I need two chained DLLs? Does anyone know of an example that shows how to do this properly? The Xilinx Application Note 174 ("Using Delay-Locked Loops in Spartan-II/IIE FPGAs") only shows how to chain two DLLs to multiply clocks by 4. Here is my current PLL code (generated by the clock wizard):
wire clkout0;
wire clkout1;
wire clkout2_unused;
wire clkout3_unused;
wire clkout4_unused;
wire clkout5_unused;
wire clkfbout;
wire clkfbout_buf;
wire pll_locked;
IBUFG
clk_ibufg_inst(
.I(clk),
.O(clk_ibufg)
PLL_BASE
#(.BANDWIDTH ("OPTIMIZED"),
.CLK_FEEDBACK ("CLKFBOUT"),
.COMPENSATION ("SYSTEM_SYNCHRONOUS"),
.DIVCLK_DIVIDE (1),
.CLKFBOUT_MULT (20),
.CLKFBOUT_PHASE (0.000),
.CLKOUT0_DIVIDE (4),
.CLKOUT0_PHASE (0.000),
.CLKOUT0_DUTY_CYCLE (0.500),
.CLKOUT1_DIVIDE (4),
.CLKOUT1_PHASE (90.000),
.CLKOUT1_DUTY_CYCLE (0.500),
.CLKIN_PERIOD (40.000),
.REF_JITTER (0.010))
pll_base_inst
// Output clocks
( .CLKFBOUT (clkfbout),
.CLKOUT0 (clkout0),
.CLKOUT1 (clkout1),
.CLKOUT2 (clkout2_unused),
.CLKOUT3 (clkout3_unused),
.CLKOUT4 (clkout4_unused),
.CLKOUT5 (clkout5_unused),
// Status and control signals
.LOCKED (pll_locked),
.RST (1'b0),
// Input clock control
.CLKFBIN (clkfbout_buf),
.CLKIN (clk_ibufg));
// Output buffering
BUFG clkf_buf
(.O (clkfbout_buf),
.I (clkfbout));
BUFG clkout1_buf
(.O (clk_int),
.I (clkout0));
BUFG clkout2_buf
(.O (clk90_int),
.I (clkout1));
sync_reset #(
.N(4)
sync_reset_inst (
.clk(clk_int),
//.rst(~dcm_locked),
.rst(~pll_locked),
.out(rst_int)
