Sourcing current using Shift Registers
soc
Junior Member level 3
Hello All,
I am working on a project and need to on/off 32 current source from outside a chip.
The easiest way would be to include 32 pads meanings 32 pins, which requires more space and increase cost.
So does any one knows a better way using Shift Registers, important is all the current sources have equal currents with +- 0.1% deviation.
Thanks..
You have already answered your own question - a 32 bit shift register. Only two pins required - data plus clock. If you don't want them switching all over the place you will need a 32 bit latch as well and an extra 'load' pin.
Keith.
What if I have 64 current sources and I want to control them externally. Using a 64 bit Shift Register won't be advisible because of the cost if I am right.
Can you suggest any detailed implementation example for reference.
Thanks
I am not sure I understand the problem. A 64 bit shift register will not be large on an IC. I guess I don't really understand the problem. I have implemented a 48 bit shift register on an IC for clocking in the settings for an analog IC from a microcontroller. The only connections required were clock and data, although for my particular design we also included a reset input to clear the shift register and a 49th bit which was accessible externally on the chip. They were for testing and run-time checking. While the size of the shift register was not negligible because it was on 0.8um CMOS, it was only a small proportion of the overall IC size.
Keith.
Do you have any literature where I can find how to implement a 64-bit Shift Register at the transistor level?
Thanks
I used the digital cells from the fab, although I simulated them at the transistor level. What process are you using? They should have digital cells available. I will see if I can find a D type circuit at transistor level tomorrow.
Keith
Hello,
I implemented a 1-bit SR using Transmission gates, NAND and NOT.
If I need a 64-bit do I just need to connect 64 1-bit cells?
Also in my application I will be using to on/off current sources externally and I need a high efficency meaning deviation <1%.
Thanks for your feedback.
soc said:
Hello,
Yes. It would be easiest if you create a flip-flop subcircuit and symbol to save your circuit looking huge when you draw it out.
Keith.
