Source code in C does not compile, please check it
thvigan
problem with c
i have source code written in c but i cannot compile, im not sure what is wrong with source code. can some one check the code for me. i have attached the code
problem with c
can you post the compilation errors?
and for which microcontroller are you writing?
problem with c
using the do{}while() or while(){} doesnt make much of a difference. Try use a numerical value insted of true.. like try to pass positive value within the while( condition) so as to execute the loop.
with regards,
arun
Re: problem with c
im still getting some errors i have attached the errors.
Re: problem with c
Problem is in header file. You must include header file for 16F72. For example if you use Hi-tech it's pic16f7x.h.
