SOT23 diode with Non connected pin.......what is it connectd to?
T
treez
Newbie level 1
Hello
I wish to connect the Anode and "N/C" pins of the BAT750 schottky diode with the same copper pour area for cooling purposes...is this ok?......or will i be shorting out the anode?.....the datasheet doesnt say whether the "N/C" pin is perhaps connected to either anode or cathode?
BAT750 Datasheet
Hello treez,
normaly you can do it. Take an Ohmmeter and test if N/C is connected inside to Anode or cathode. If not, it's no problem
Regards
Rainer
Reactions: treez
    T
