Something Wrong When running Synopsys Magellan
mrchiao
Newbie level 1
Newbie level 1
The VCS and DC works good,
But When I run Magellan, I got the Errors bellow!
Please give me some help!
======================= M A G E L L A N Install Test ============================
>> Setting MG_HOME to /tools/synopsys/magellan201209
Magellan (mgsh)
Version: G-2012.09 (linux - Aug 29, 2012)
Copyright(c)1988-2012 by Synopsys, Inc.
ALL RIGHTS RESERVED
This program is proprietary and confidential
information of Synopsys, Inc. and may be used
and disclosed only as authorized in a license
agreement controlling such use and disclosure.
Client Server Name: localhost.localdomain
Alias: localhost
Address: 127.0.0.1
Port: 5555
Explore Server on: localhost
Build Server on: localhost
Run Server on: localhost
>>>>>>>>>>>>>>>>>>>>>>>>>> Checking Environment Variables <<<<<<<<<<<<<<<<<<<<<<<<<<<
-- checking: SYNOPSYS
> /tools/synopsys/dc201003
-- checking: MG_HOME
-- checking: VCS_HOME
> /tools/synopsys/vcs1112
-- checking: SNPSLMD_LICENSE_FILE
> 27000@localhost.localdomain
>>>>>>>>>>>>>>>>>>>>> Checking Required License Feature Tokens <<<<<<<<<<<<<<<<<<<<<<
** All Licenses are accessible!
>>>>>>>>>>>>>>>>>>>>>>> Testing Property and Coverage run <<<<<<<<<<<<<<<<<<<<<<<<<<<
>>> Start Session: ses3
----- Initial VCS Compile (12:24:02 PM - Oct 09) -----
*** Error: (HVB-035)
Simulation compile failed.
*** Information: (HVSH-350)
Information about the build has been added to the build log.
Use 'stat -build' to view it.
*** Error: (HVB-502)
Simulator compile for HDL analysis failed.
See compilation output above.
*** Information: (HVSH-408)
Use the 'list_session_results' command to get detailed results on all property/coverage modules.
*** Error: (HVSH-353)
Build (session: ses3) *failed* at time (12:24:04 PM - Oct 09).
Use 'stat -build' command to see results.
CPU Time = 0.56 (s)
Elapsed Time = 9.81 (s)
Peak Memory = 63.00 (mb)
Max Memory = 63.00 (mb)
*** Error: Build Failed!
********************************** INSTALL FAILED! **********************************
Shutting down...
