Some questions regarding Inverters (VFD Drives) by YASKAWA ?
danishdeshmuk
Advanced Member level 1
Some questions regarding Inverters (VFD Drives) by YASKAWA :
1) What's PG card ? Why its used in inverters ?
2) What's PG encoder ? Why its used ?
3) What's Z Pulse & Z Pulse Fault ?
4) What's node setup & hence node setup error ?
5) How to check the ratios between voltage & frequency if V/f setting is not operating as expected ?
6) How to Check the maintenance time for the capacitors ?
7) How to check maintenance time for the IGBTs ? How can we get to know this ?
8) How to check/measure the drive temperature ?
thanxxX
Complete Answering to all your questions
would need to write a few hundred pages thick technical manual.
It would be more wise to ask only one significant question in one post
Read ...
2 Introduction and Component Names and
6 Application of Encoder (PG)
PG SPEED CONTROL CARD PG-X2
Varispeed G5/F7/G7 OPTION CARD INSTRUCTIONS
---------- Post added at 23:07 ---------- Previous post was at 22:25 ----------
Read pages 1 and 2.
Electric Motor Feedback Devices
http://www.motor-solutions.com/datasheets/servo_motor_feedback_devices.pdf
Generally speaking : Quadrature Errors
are failures of the encoder to generate properly formatted quadrature signals.
Most typically, these are failures to create the proper 90° signal separation between
the A and B channel outputs, with a less than perfect stream of square waves.
Most controllers, when presented with a quadrature error, will report a drive fault or
encoder fault and then shut down.
specifically for PG card (Yaskawa) and Z-pulse errors
Read...
6 Troubleshooting
◆ Error Codes Displayed on the Drive Operator
YASKAWA AC Drive-Option Card
Line Driver Type PG Installation Manual
Z-phase Pulse Fall Detection
The motor turned one full rotation without the Z pulse being detected.
Z-phase Noise Fault Detection
The Z pulse is out of phase by more than 5 degrees for the number of times
specified in parameter F1-17.
The objective of this Technical Note is to demonstrate how to set up
a network with 2 or more nodes over either Mechatrolink or DeviceNet.
YASKAWA TECHNICAL NOTE
MOTION PRODUCT AND ENGINEERING GROUP
Subject: MP940 Network Setup via MotionWorks +
---------- Post added at 10:50 ---------- Previous post was at 10:19 ----------
Read this very careful....
Read pages 152....
Parameter group E : Motor settings
http://www.scrcontrols.com/docs/TM.V1000.01.pdf
thanks a lot ......... ufffffff . yeah it was massive , sorry about that KAK111
some questions are remaining and needed to be answer by KAK .... from 6 to 8
how to place either the thermal camera or non contact infrared thermometer inside the drive ?
Thank you for you interest Yaskawa product if you have any more question or concern please contact our Yaskawa technical support department by clicking the following link **broken link removed**
